The CL-43 is CNC machined from extruded 6061 aluminum. The light operates via a rearward-click button located midpoint of the flashlight with both constant and momentary-on capabilities.
The exterior features our patented nonslip pattern common with our firearms. Surfaces are either hard-coat anodized or Cerakoted™. Five colors are available:
Tactical: Black, OD green and Desert tan.
Safety: Orange and yellow.
Unique features of the CL-43 include:
- Superior ergonomics due to the forward facing push button switch.
- Small size. Can be enclosed by one hand and operated in parallel with a handgun.
- Extreme light power. 420 lumens and an optimum beam angle.
The CL-43 operates on three CR123 Lithium batteries and features Cree XP-G LED.
Its weight with batteries is 107 g (3.8oz), and size is 24x38x102 mm (.94x1.5x4"). (Height x width x length).
The switch is operated like the trigger on a gun, pointing the light as an extension of your arm. Compared to a light mounted to a pistol, the CL-43 has much superior range, and also keeps the ability to hold the light off the line of sight to conceal your position.
The small size of the CL-43 makes it possible to hold and operate parallel with a handgun without impairing a conventional two handed hold. If required, and with some training, the light can be operated one-handed together with the gun.
With the addition of a separate attachment, the CL-43 can also be mounted to a MIL-Spec Picatinny. An integrated belt clip and lanyard ring add to the versatility of the system. With a separate adaptor, standard AA batteries can be utilized, however, at an increase in length of the system.
The powerful CL-420 LED Module is also used in our CL-42 conventional flashlight and the KSG Tactical Shotgun.
CL-43 MSRP: $140.00
CL-42 MSRP: $ 80.00
As with all KEL-TEC products the CL-43 is designed, developed and manufactured in the United States. Patents Pending.
To learn more about Kel-Tec CNC, visit
www.keltecweapons.com. For any further questions or requests, please contact Monica Arnold, PR Director for Blue August at
[email protected].
