Keyed or keyless drill chuck?
Mirage_Man
Florida
I am in need of a new drill chuck that has a capacity of at least 5/8". My current Jacobs keyed chuck is 1/2". I'm hoping some of the more experienced machinists (cough...Barry ;)) will have some advice on whether a keyless chuck has the gripping power of a keyed chuck?
Edit: I thought I should mention that the chuck will be used almost exclusively tail stock mounted on my lathe. Not that it matters but it's got a 3MT mount.
For 5/8ths capacity, I'd look at a large Jacobs chuck. A 16n would be a good choice.
I would look for new old stock or a used one. Jacobs has offshored manufacturing to China. Early reports say quality not the same.
If money is no object, and this is for a production environment, get an Albrecht keyless chuck. I haven't used one that big, but if they are as good as the smaller ones, they are the best, provided you are using it in the RH direction, they let go in the LH direction.
Edit: I really like the SPI brand Ultra Precision drill chuck. I didn't recommend it at first because I didn't know they made a 5/8ths capacity model. I have 2 of the 1/2 capacity models in my shop and I think they are bargains. Albrecht style and well made in Taiwan. Penn tool (whom I've never dealt with) has them listed at $109.85 http://www.penntoolco.com/catalog/products/products.cfm?categoryID=1574
Edit #2: Enco has it on sale. Says they are discontinued: http://www.use-enco.com/CGI/INSRIT?PARTPG=INSRAR2&PMAKA=319-3106&PMPXNO=19506511 $72.95
I'm sure with Enco you can return it if unsatisfied. You'll eat the return shipping though.
For lathe use, a keyed Jacobs Super Chuck is hard to beat. The best approach (IMO) is to have a small chuck like the 11N or 14N, plus a big chuck like the 18N or 20N. The little chucks do a nice job on small shanks, while the big ones grip like death ... the 20N has 4X the grip torque of the "standard" 14N.
http://www.jacobschuck.com/images/products/super chucks Update (ENG).pdf
My 14N and 20N trade places all the time :nana:
IMO, the Albrecht keyless has at least as much grip torque at the Super Chuck 14N, and probably as much as the 16N or 18N. They just cannot be made to slip. But any keyless chuck, including the Albrecht, may not be the best tool for tailstock use.
For drilling & holding straight shank reamers, the keyless does a nice job. Tapping is the operation that causes problems. If you don't power tap in (& power reverse out) the Albrecht will do fine. If you plan to do much tapping with the chuck holding the tap stem, stay with the Super Chuck.
I would look on ebay
Yup, gotta love ebay, got my 5/8 Bison chuck for $56 shipped brand new & I love it although the only other chucks I've used were China keyless chucks here at home & the Jacobs 14N & 16N in shop class. Next course starts in 2 weeks. :party:
I bought the SPI precision keyless from Enco and am thrilled with the quality. I also have a 5/8 Rohm that I'm not sol thrilled with. I would recommend the SPI!
Mac
Mac
So it works good in your tailstock? How well do you think it will work holding that 5/8" drill I told you about?
Hold you say :)
I was 3" into a hunk of Ti when a chip got caught. The chuck never slipped but did come off the arbor TWICE!
I had to really hit the chuck onto the arbor. I have not had a problem since.
Mac
Same thing happened to my Bison keyless used on the mill ... put it on eBay & got my money back, bought an Albrecht with integral shank.
No way that one will ever slip :nana:
I was not expecting it to be as tall as it turned out to be.
Some setups are Z challenged :D
For those, instead of a drill chuck, the ER-40 collet chuck makes a much shorter setup. First, it projects a shorter amount below the spindle nose. Second (and of even more value) is that the twist drill can be pushed way up inside the collet so that the collet grips the flutes of the drill instead of the shank.
If a screw machine drill is used, the drill projection is often tiny. That also give a more rigid setup & the drill point is less likely to wander when starting a hole.
Thanks to you Barry that's what I use in my mill. I have not had the need to take the collet chuck out of the mill since I got it :). I suppose I could have used in it in the lathe except for the fact that it has an integral R-8 shank.
I have no troubles using the SPI keyless chuck in the lathe. I specifically have 2 of the same chuck, one with R8 shank and the other with a MT3 for the lathe.
Click on this link & go to page 21: http://www.plazamachinery.com/files/metal8-11-2010.pdf
ALBRECHT SUPER SPECIAL
We have some excellent, keyless ½" Albrecht chucks, made in Germany. We selected our best chucks in stock, disassembled, cleaned. They are quality, smooth operating used chucks, $100.00 (new are about $250.00) Specify shank needed, Morse 2, Morse 3, ½" straight add, $6.00. For R8 shank, $23.00. Shipping in the 48 states is $7.00 (see our return policy if not completely satisfied).
Albrecht, made in Germany, 5/8 capacity, very beautiful with R8 shank, $140.00
An Albrecht for $100 is a better deal than can often be found on eBay, and Joe is easy to work with. I have my paycheck direct deposited to his account:crackup:
Yes, but is that an integral r8 shank? If it is I can't use it in my tail stock.
Those Glacern chucks look nice. Have TiN cotaed jaws & the price is very good. I was going to get one with a MT3 integral shank but they sold out very fast when they first started offering them so I ended up getting something else.
