Hey BVH,
In addition to your questions and comments, with all the POB's floating around the forum, I'd love to see how the L35's new 35w 4200k and redesigned reflector fairs against a POB modded with a 4300k. That should make an interesting shootout :touche:
This was all done before in the link below.
Just remember the the AI is the POB with a 4200K bulb.
Also remember that the "Secret 35 watt" was a prototype that will not be in the US that had the L35 bulb reflector and ballast.
http://www.candlepowerforums.com/vb/showthread.php?t=199730
I will mention once again DO NOT expect the L35 to be significantly brighter then the N30, if at all.
The N30 became "30" because driving these 35 watt bulbs at anything lower was not producing good results. At approximately 30 watts the bulb is now driven enough to achieve the surface temp necessary to work properly. The original hand made prototype was driven at 24 watts. BVH and myself are the only CPF members that have ever seen that model in operation.
Because I own it and he was the only one I trusted to see it way back then
The L35 is NOT overdriving the bulb so it will not be appreciably hotter and therefore will not be significantly brighter. The reflector makes more difference.
There is also a + or - 200 lumen variation from bulb to bulb that will have more effect on the light output then the difference in wattage between the N30 and L35.
So be fore warned for the umpteenth time.
If some of you have a N30 with a really good bulb and get an L35 with a decent bulb.
Your N30's will very likely look brighter.
Also remember that HID's have a break in time so those of you that use your N30's regularly will be comparing a broken in HID bulb with a non- broken in HID bulb.
I have said MANY TIMES the improvements in the L35 are not light output, but ALL of the other things that Matt was willing to do that he listed in the first post in the marketplace thread.
Matt did a fantastic job and I don't want him to have any heartache because of light output when I have been stating this information from the VERY BEGINNING with the very first N30 and L35 prototypes and even in the VERY FIRST announcement thread where the N30 prototype actually very slightly out peformed the L35 prototype for total light output and throw. That original announcement thread was posted nearly 2 years ago, "03-10-2007, 09:39 PM". See for yourself below-
http://www.candlepowerforums.com/vb/showthread.php?t=156617
Take Care,
mtbkndad :wave:
