ntalbot
In short:
I bought a lightly used L35.
If you charge it and do a runtime test same day you get 1hr 40min.
If you charge it and let it sit for a few days, you get about 50 min. Lithium polymer should not loose its charge that fast, right?
So I take the battery out to look at it, and this is what I found:
There is a weird solder blob on the battery:
Here is a close up:
The battery looks a bit cracked (maybe heat damaged?):
Inside the battery compartment this is what you see:
So there is a weird third contact inside the battery compartment that has no corresponding contact on the battery, except a blob of solder. It looks like a spring or a machine screw with a blob of solder on it.
I sent the L35 to batteryjunction and they said the extra contact inside the battery compartment is normal, but the solder blob on the battery is not. They are charging it today and will let it sit for 5 days and then do a runtime test. I am pretty sure they will replace the battery if there is a problem with it.
If you have an L35, please take look inside and at the battery and tell me what you see. I would especially like to hear from anyone with a brand new L35 that has not been used yet: Can you get a clear picture of that third contact? Is it a spring or just a machine screw? Does it have solder on it? Does your battery have solder on it?
This whole thing is really weird. I have a theory, but I would like to hear from other L35 owners before I put it out there.
Neil
UPDATE: BatteryJunction is replacing the battery with a new one! Thank you Matt and Jeff!
Here is a close up:
Neil
