I'd like to update my earlier review now that I have had some time to use it.
It no longer seems so big and heavy. Now it seems more rock solid than rock heavy. It feels unbreakable in the hand. I like that. Also the front-heavy balance issue is no longer noticable.
In real life usage, I find it fits in all my coat pockets just fine. And it will fit in a pants side pocket as well, when necessary.
I continue to be impressed with the pure-white light color, intensity, and beam quality. It has a good hotspot and throw but also broad side spill. Excellent for outside work at night. If anything, it's too bright for some EDC needs. I would love a LED light like this with adjustable intensity.
I like it. If I lost it, I would order another.
[ QUOTE ]
mporter said:
Fed Ex just delivered my L5. Here are some first impressions.
Weight and size - my subjective experience:
I was a bit shocked by the size and weight compared to my A2. From pictures I had seen I didn't expect it to be so big and heavy. The A2 is somewhat pocketable. The L5 is not. The L5 is more large coat pocket pocketable. Surefire calls the L5 a "Combatlight."
Ergonomics:
My first impression is that the attached clip is very uncomfortable in the hand. Perhaps I would get used to it in time, but my first act was to to remove it. Also, the balance seems very front heavy due to the large bezel. However, this "out of balance" first impression begins to fade as I continue to play with it.
Light:
Very bright, very white hotspot with good side coverage. Excellent beam quality. Very impressive. It's only 11:30 AM here and I will have to wait till dark and take it for a real walk.
I am glad I bought it but note that I am a recently addicted flashaholic and bought it to see what Surefire's latest product using a 5 watt LED would do. Note again that these are just quick first impressions. I need to live with a product for some time before I would trust my opinion.
I wonder how hot will this thing get? There is a special insert in the packaging warning about leaving your L5 on when under anything that would prevent air-cooling. It says, "If the material is combustible, this could raise the possibility of fire."
[/ QUOTE ]
