Large'ish rechargeable with zoom head
mattmatt
Essentially i'm after a large'ish torch with internal charging, adjustable beam head and good light. Something like the MH40GTR would be ideal but it doesn't have an adjustable head. Thanks!
- This will be mail-order or Online (location doesn't matter).
2) Budget: An easy question, but you may change your mind after answering the rest! :)
- Up to $200.
3) Format:
- I want a flashlight (hand held/self contained).
4) Size:
- MEDIUM/LARGE
5) Emitter/Light source:
- LED (known for efficiency, longevity, and compactness)
6) Manufacturer:
- I want to buy a light from a large/traditional manufacturer that is ready to go out of the box.
- I intend to use Rechargeable cells based on less common formats (18500 or 18650 Li-Ion, RCR123, et-al).
- I don't care
- I want search and rescue type illumination (800+ lumens).
- SPECIAL NOTE: Burst/Turbo mode Category - There are several lights that will run at a super bright maximum for a very limited period (usually 5-10 minutes) and then will "step-down" to a lower level for thermal control. Check here if this is acceptable.
- Wide Throw: I want a beam with a noticeable hot-center for distance throw and a significant amount of "side-spill". Good for rough trail hiking, search and rescue, and general distance work.
- 50-150 yards/meters (I live in a very rural area/farm with wide open spaces)
- 30-60 minutes (I have plenty of batteries just ready to be changed)
- Slightly Important (Walks around the neighborhood).
- I don't care.
- I don't care.
14)Material/Finish/Coating
- I don't care.
15) Water resistance
- None needed
16) Storage conditions
- In house (temperature/climate controlled environment)
- Zoom head (spot to flood is it called?!)
