[ QUOTE ]
SemiMan said:
There are a few things at play here. The lens of the eye is fairly simple in nature. It is a little better than a simple spherical lens, but certainly not aspheric. To that end, it can not focus all colors to the same spot. To that end, removing some of the colors could enhance focus. That of course, could mean either removing red, or removing blue, but generally, removing red will be better. However, do not confuse this with sunglasses that remove blue and suddenly make things much sharper. By removing blue from a scene, they are generally removing a lot of haze, etc. which tends to be on the blue end of the spectrum. Hence, it is like removing fog from the image. If you are wearing sun glasses, we can pretty much assume your eyes are already pretty closed up so you are getting maximum depth of field in your vision.
I don't know if it is accurate to say there is more red in regular daylight. Regular daylight is actually quite blue (5500K+), and on a hazy day can be much higher than this. So I wonder if your eye does focus on a particular color, or if it focuses on general brightness? .. any experts out there?
Given equivalent light, your IRIS does respond mainly to blue, and by closing your IRIS, you are going to get a signficant increase in depth of field, which is likely to be a far greater increase in apparent focus than from the ability to focus different colors.
Semiman
[/ QUOTE ]
Semiman,
The eye's lens is aspheric; I think you meant it isn't achromatic, which is true.
The eyes optics have a great deal of chromatic aberration, about a diopter and a half's worth or so. (I measured it a few years ago, but don't have the exact figures handy.) In fact, the eye relies on the differing focus between the colors in one of several servo loops maintaining optimum focus overall (by balancing red and blue defocus, green focus is optimized).
Briefly, the eye's optics have a longer focal length for red light, roughly neutral for green, and shorter focal length for blue.
Accordingly, a nearsighted (myopic) person's focus is improved by red light, and worsened by blue. Vice versa for farsighted (hyperopic) folks.
The effect is on the order of a diopter, as noted above.
Blue light, by the way, is damaging to the retina, in the same way as are other shorter wavelengths (e.g. ultraviolet). Cumulative exposure is a principal cause of decreased contrast and sensitivity (nightblindness) in elderly people. Ditto for cataracts, which are in large part a result of damage done to the eyes' crystalline lens by short wave light.
Cheers,
Jamaica
