The advice in one word is
STOP! You are about to make your headlamps unsafe and illegal. "LED bulbs" -- any and all of them -- are unsafe, illegal, and not legitimate. There's a good, recent, detailed explainer
here, and more general principles
here.
Headlight bulbs are not like household light bulbs. In the house (office, garage, etc) it's pretty much a matter of putting in whatever bulbs put out the amount and type of light you consider adequate and agreeable. Headlamps are life-safety equipment, so they have to work
right (just lighting up is nowhere near good enough), and they are precision optical instruments so they can only work right when equipped with the intended type of light source. For your car that means you really need to stick with halogen bulbs. There are
better halogen bulbs than the originals, so you can improve the lamps' performance without making safety problems, and if that doesn't improve them as much as you want you can swap in the HID headlamp assemblies that were offered as an option on that car, but "LED bulbs" (and "HID kits") are a big, solid
NO. (This is not a point we argue here. The lighting modifications and products you're asking about are both illegal and unsafe, and
Rule 11 of this board sharply limits discussion of illegal or dangerous activity.)
