Northernflame
- Joined
- Sep 23, 2004
- Messages
- 145
Hi.
I'd recomend the terralux ministar (unless you want colour other than bright white).
http://www.luxeonstar.com/
It should be noted that I too had minimaglites (AA) that ate batteries and bulbs (krypton) continiously.
I contacted maglite...
As per Maglites sugestion I replaced the bulb sockets with the new verions. Problems solved, also the reflectors/colimnators in the old version maglites are longer/taller than the new ones.
As with the opalec LED minimag conversion as well it states that the new recent modele of maglite is required. The old modele seems to missing some holes. The holes are two slots on either side of the bulb mount. To which the Opalec led bulb sits into.
http://www.opalec.com/
http://www.kidenergy.com/21-0100.html
Since the AA and AAA mini maglites are so small a proper driver circuit is recomended.
Obviously the Opalec would have a longer battery life.
However my luxeon ministar conversion last 8-9 hours form a fresh set of battereis.
Now if you take a 2AA luxeon flashlight such as the streamlight luxeon Jr. It's basicaly direct driven as the batteries only last one hour.
/ubbthreads/images/graemlins/smile.gif
I hope this helps.
yt
NF
I hope this helps.
yt
NF
