karlthev
Great info...thanks!
Karl
Karl
.............................Any reason why xeray doesn't make a new design with UHP or xenon/mercury short arc systems?
Should be able to get tens of millions of candela, a significant upgrade.
I mean, xevision did mention in that post that they would make their own ballast...Unfortunately it's very, very unrealistic to use UHP bulbs in a production light. Removing the bulbs from their glass reflectors is dangerous and not suitable for a production environment. There are also no DC ballasts for these bulbs (except for the Philips Ujoy 50W bulb which is not very bright). You would either need to develop your own ballast for them (no projector company does this, they all use standard Philips/Osram ballasts) or put large inverters into the lights. This reduces efficiency and increases size dramatically.
In the end you would get an extreme thrower with a slow warm-up time and a much lower total system efficiency and thus lower runtime. Switching out the bulb wouldn't be realistic anymore for the customer because these bulbs require protective clothing and proper training whereas the Lemax uses relatively cheap, standard automotive HID bulbs. As far as I know these bulbs are also not meant for hot-restiking.
in addition to this you would probably also need active cooling for safe, continuous operation.
Xenon short-arc does seem nice at short glance, but there are some signifigant drawbacks:
1. Xenon short-arc systems are super inefficient
2. Xenon short-arc bulbs run with low voltage and high current => large component sizes lead to large, heavy power supplies
I guess you could try maybe a 150W bulb with ~4500 lumens (if possible with just passive cooling). You would need a specially designed ballast though to make it useable in a flashlight tube.
That's the name of the guy who posted earlier, if you scroll up."august99".....??
Karl
Thought I'd pass this on if anyone else is worried about scratching the lense on the behemoth. Found these on Instagram and thought it might work. Search for "inspireuplift.com" and look at favorites. Fits like a glove. One also fits the LX50...:devil:...........and it also looks like the next size would fit the LX70.
Aweosme found them on the website! Also i own the AceBeam X70 and I think one of these lids may fit that too! Thanks!!
