Lens filter needed
Thanks for the link, I have been looking as well,
mostly found new lenses (which would work)
but I want a "cap" type, for easy switching.
Do you know if these are a replacement lens, or cap?
They are a replacement for the standard glass.
To fit the filter, you have to unscrew the bezel, take out the old glass + 'o' rings and refit the new filter with 'o' rings in the same sequence. Takes a couple of minutes *.
The filters in the pack that I have are slightly thicker than the actual cover glass, so the bezel doesn't screw back quite as tight.
I, too, would prefer a filter that can be capped over the end of the bezel. I did wonder if one of the Surefire ones would fit - until I realised that would cost more than the light itself ! :ohgeez:
____________________________________________________________________________________________
*- plus of course eleven minutes' worth of swearing and trying to wipe fingerprints off the inside of the glass !
