Re: LF HO-9 question
they come off the charger at 4.2V, but when you load em with a 1.5A load, they immediately sag to about 3.7V, followed by a continuas slope down to around 3.1 before you should stop using the light...
The HO-9 paired with RCR123s, is a nice combo for short bursts, that you can recharge frequently to get the "fresh off charger" brightness, but should not be used as a continuous duty light of sorts. Technically speaking, it would be best to recharge after 10 minutes runtime, rather than draining them all the way down, because li-ion cells do not like to be sagged down that low under a load, it wear them out very fast.
In all honesty, I suggest the SR-9 or ES-9 over the HO-9 for most people when dealing with RCR123 size cells.
Notice, the SR-9 is also rated at 7.6V, but in almost all cases, since it is a lower current lamp, it will get higher voltage from the cells in question. SO while it is rated 220 lumen instead of 320 lumen at 7.6V, you get less "loss" from small cells..
So.. for comparison.. I figure the following:
HO-9 on RCR123s: ~280 diminishing to ~160 lumen in around 20 minutes
SR-9 on RCR123s: ~220 diminishing to ~140 lumen in around 30 minutes
ES-9 on RCR123s: ~170 diminishing to ~110 lumen in around 40 minutes
Now.... if you had a body that could support an 18650, you could use an EO-4, and get about 210 lumen diminishing to about 130 lumen with a runtime of about 45-50 minutes. Similar to running the SR-9 on RCR123s performance wise, but a good chunk more runtime.
