LF-HO-M6R bulb - Help
oren1s
IL
I need some help as i'm thinking of getting SF M6. What do you think of the above bulb in compare to the SF MN20&21?
Where can i get best price for the HO-M6R?
Does the M6 have some modified led options?
Thank you all for your help
Lighthound sells the LF LAs and I'm sure other dealers do, too. I have an HO-M6R in transit and bought a set of Li-Ion RCR123A cells so I hope to able to experiment with this combination soon.
um, the HO-M5R allows you to run rechargeable 3.7V RCR123s in your M6. That's what makes it different than the MN20/MN21. The MN20/21 will not survive the voltage of rechargeable cells in that configuration. The HO-M6R falls in-between the brightness of the 2 SF lamps.
Thanks,
I saw one of the members is using AW`s 2 C Li-ion cell in M6 with MN20 or 21.
If this setup is working i think its best, what do you think...?
Thanks,
It's totally up to you - preferred setups are entirely objective.
If you happen to like fivemega's 2xC li-ion and extender solution, then nobody can take that away from you. For what it's worth, it is an excellent option.
There are now quite a few options for turning your M6 into a rechargeable light - and the decision as to which is best rides solely on you, because you are the only person who can take your own desires into consideration.
