Toolslinger
- Joined
- Oct 27, 2015
- Messages
- 2
I've got a Big Larry Pro that is fabulous when it's good... It sits a couple weeks between uses as it lives in PA, and I'm in NJ. So what I find is it seems to develop some level of corrosion I guess at the threaded connection, either at the tail cap, or further up near the top of the battery. Screw it apart, and together a few times, and it seems to clear, and all is well for a little while.
I've had similar issues in the past with Mini Mag LEDs, but not to this extent, or frequency.
Thoughts on keeping the juice flowing? When I need the kind of light the Larry is, I typically really need it, and it's annoying having it cut out, or dim randomly... This will occur right off the charger, so not due to low charge. (unless the battery is shot, but it doesn't seem that way)
