gcbryan
I've noticed there are several phases that people go through as they learn about lights and acquire them. Not everyone is the same of course....more output...less output...cheap...expensive...cheap again (or not)...whatever the trend...
I'm curious as to how many of you (unless you're primarily into collecting lights) have, as a result of your learning curve, found the functional group of lights for your needs and then stopped there?
I've bought some lights of various types just to try them out firsthand. As a result, at the moment anyway, I'm satisfied and am not really looking at buying more.
I have a small simple light that I will actually carry with me most of the time (1 AAA one mode twisty).
I have a 5 mode CR123 light that is still small but with a little more versatility that I keep in the car.
There is a Surefire 6P that was a gift that stays in the nightstand next to a pistol.
For longer burn times and for more output if needed I have a XP-G light using one 18650 so using it freely is no problem since I can recharge it.
Lastly, just because...I have a Photon Pro that is versatile and yet isn't used as often as some of the others. I like it because it's small (1 AA) and can be worn around the neck and then tucked into my shirt. I use it camping, when rock climbing when the sun may go down on me before I get out of there and for any other reason when you want to be able to ramp the output to a very low level.
That covers everything for me.
If I was collecting I would have a thrower, a flood, a ...and the list would go on but as far as what I actually need a light for I think I've got it covered. (I actually have a cheap thrower as well as several other lights that were part of the learning curve).
I also have a green laser pointer that I consider more or less in the flashlight category. I just got it but am looking forward to being able to go climbing in the wide open spaces and use that a bit just for fun and it could be useful when discussing a route.
How many of you have found your small group of lights? List them if you care to along with your reasoning as to why they are in your "group".
