List of most of Surefire's Tailcap Switches - with IMAGES
tazambo
Tasmania, Australia
After looking, to determine what the standard tailcap on my 9P was called, I realised that with all the Surefire tailcap switches out there, there is, post after post, looking for this information and nowhere was all this information in the same place.
I'm hoping this post will become a sticky or be listed in Unforgiven's General Flashlight Forum - Threads of Interest sticky.
As most would be aware, a lot of this information has come from posts by Size15's, Al, aka the Surefire Information Man. I'm sure he'll post to help correct any errors, so I can update this original post.
I'm looking to add pictures of most, as I find them.
TAILCAP SWITCHES:
Standard Bodies refers to - C/M/D/P/R/Z/G
Z14 - TailCap (Classic) Three parts (for Standard Bodies)
Z21 - Black twisty only with ring attach point (for Standard Bodies)
Z23 - Diaphragm Sealed - waterproof - (Classic) (for Standard Bodies)
Z31 - Tailcap group non LOTC (Raised) (for Standard Bodies)
Z40 - Black lockout (Not waterproof) (for Standard Bodies)
Z41 - Black twisty lockout - stock on 6P, 9P, Z2 etc (for Standard Bodies)
Z41 - Natural HA twisty lockout - stock on C2, C3, M1, M3 etc (for Standard Bodies)
Z48 - Natural HA clicky with rubber shroud (for Standard Bodies)
Z49 - Black clicky with rubber shroud (for Standard Bodies)
Z52 - Natural HA twisty lockout (E series)(*Discontinued*)
Z53 - Silver twisty lockout (E series)
Z53 - Gun Metal twisty lockout (E series)
Z54 - Black twisty lockout (E series)
Z57 - Natural HA clicky (E series)
Z58 - Natural HA clicky (for Standard Bodies)
Z59 - Black clicky (for Standard Bodies)
Z59 - Black HA clicky - standard on the U2
Z61 - Black HA clicky (E series)
Z62 - Natural HA two (2) stage twisty for A2,L1,L2
Z68 - Black HA clicky with metal shroud (E series)
Z72 - Black twisty lockout - stock on G2-BK
Z73 - Olive Drab twisty lockout - stock on G2-OD
Z74 - Yellow twisty lockout - stock on G2-YL
Z75 - Tan twisty lockout - stock on G2-TN
SW01 - tactical twisty (for Standard Bodies)
SW01 slim - tactical twisty (for Standard Bodies)
SW02 - tactical clicky with rubber shroud (for Standard Bodies)
UExx - tactical pressure tape switch (xx = length in inches) (E series)
UMxx - tactical pressure tape switch (xx = length in inches) (for Standard Bodies)
XMxx - tactical pressure tape switch with push button (xx = length in inches) (for Standard Bodies)
Regards
Dave
tazambo
Tasmania, Australia
Re: List of most of Surefire's Tailcap Switches
PHOTOS OF THE TAILCAP SWITCHES
Images sourced from all over the internet, if you believe I've used one of yours, and you're not happy. Please let me know and I'll remove it. If you own any of the switches and would like to supply me a better quality image or angle, please do so.
No Image Yet
No Image Yet
No Image Yet
No Image Yet
Z41-BK - Black twisty lockout - stock on 6P, 9P, Z2 etc (for Standard Bodies)
Z41-HA - Natural HA twisty lockout - stock on M1, M3 etc (for Standard Bodies)
Z53 - Gun Metal / Satin Grey (GM/SG) twisty lockout (E series)
[Z59]* - Black HA clicky - standard on the U2 (*This TailCap has no Z number)
Z68 - Black HA clicky with metal shroud (E series) (note that the Z68 is not scalloped like the E2d TailCap also shown here)
No image yet
Regards
Dave
Size15's
Kettering, England
Good start both of you.
Dave, I'm just itching to edit your post to make corrections...
I will with your permission, or I can post them for you to edit in yourself...
tazambo
Tasmania, Australia
Al,
Go ahead and knock yourself out (correct away).
As long as I still have access to add more info myself at some stage.
I thought in the 2nd post with the images, I'd like to list under the description but above the photo all the flashlights that the particular tailcap came with as standard.
I did a reasonable amount of searching and found that you answered these types of question over and over again and there were a few excellent reference posts with about half the switches listed, but never all of them.
Regards
Dave
labrat
I have this, a twisty, non-lockout SatinGray, from an early E1 EXECUTIVE:
Is this an early z53? It is obviously smaller, and non-LOTC.
Size15's
Kettering, England
I have one too:
It is not an early Z53. The Z53 replaced the non-LOTC TailCap. Same with the Z52 (HA) and Z54 (BK).
Not all TailCaps have Z-numbers.
The 9N and 9AN TailCaps don't.
The E2d TailCap doesn't.
Also, the U2 and K2 TailCaps don't.
etc etc
greenLED
La Tiquicia
I called once to inquire about a replacement tailcap for my A2-BK-WH, and they informed me they do have those available. I don't know if they'd have a different part number.
Please note I didn't really need a replacement tailcap for my A2, I just wanted to make sure that I'd be able to get a replacement in the event of mine failing at some point.
Size15's
Kettering, England
If it has a Z-number (which I doubt) the Black HA version of the Z62 is likely Z62-BK although SureFire would likely refer to it by its product code number.
Al
ampdude
USA
I'm pretty sure the Z54 is not hard anodized black, but rather type II. I had one an on older E2E, it was not hard anodized.
Now the Z61 on the other hand is definitely hard anodized, of course.
shinbone
Oregon
Great list! I would only ask for some type of marking system which would indicate to the viewer which tailcaps are no longer produced (i.e., SW1* with a note at the base of the list stating *No longer manufactured).
