Looking for 18650 XP-G R5 host
you are looking for a host, but do not want a drop in.
Thats what a host does... it hosts a drop in. You can not have a host without a drop-in.
:thinking:
Should consider the host option so that head upgrades are cheaper and easier when new LEDs come out.
Maybe don't use DX drop ins?
Just get a solarforce host & a nailbender R5 drop in. You'll be laughing. Might set you back around $80-$90 all up but it's well worth it.
You have better chance to have a reflector's profile dedicated to the LED with drop-in modules than with upgrading an XR-E flashlight to XP-G.
Viewing angle of XR-E is 90°, viewing angle of XP-G is 125°. I don't know if it makes a great difference but a reflector for XR-E will probably not focus the beam of an XP-G emitter correctly.
Just a 2 cents guess.
As I already said I've crashed one of his drop-ins ("I've burned all my Drop-Ins I've bough here")...
I think I'll give the AKOray AK-12 a try :)
How did you burn nailbenders drop ins? I have a SST-50 and SST-90 drop-in from him and they are both direct drive. The only thing that burns when I use a large IMR battery(26500 or 26650) is the McClicky switch. I follow his instructions to a T and have never burnt of poofed anything from him.
Ran the light for ~6.5 hours on high (used six fresh 18650 Trustfire 2500) ... Thats all. After about 5 hours the LED turned to a strange blue tint. Bought the Drop-in from a member here, maybe it was damaged ...
Which LED is this and it is regulated with a driver or direct drive?
My SST-50 from nailbender is a single mode direct drive that pulls atleast 4amps(AW IMR 26500 battery), I can not run it for more then 30 mins in my hand because at that point it burns my hand. If you can hold the light in your hand after 1 hour that means your host is bad(not the drop-in unless your host is big with a lot fins for heatsinking) and has no thermal path for the drop in.
You will need some copper tape to fill in the gap and also AS5, this way the heat will transfer from your drop-in to the host.
And if you're running a high-power hand light without holding it, you're abusing the poor thing. Most high-power LED lights do much of their cooling through your sweat glands.
