VidPro
Re: Plastic Welding
it might be ABS? when we "glue" plastic here which we do lots of stuff in plastic, we FAR prefer to "Solvent" the plastic itself then "Meld" the parts together as a single piece, as opposed to "weld" if you get the right solvent for a plastic, it softens it into goopey liquid, then once the solvent leaves, you have the plastic itself holding it.
with ABS (i am not sure it is that) we let the solvent SIT on it for a while, and rub a second piece of ABS into the solvent, making a sloppy goop that when dried forms a bond that is the material itself.
same thing with acrylic, they have acrylic solvents, and THICK acrylic solvents, but i am sure that isnt acrylic.
if you have to use a glue that is not Solventing the plastic itself, the LEAST is to sand it harshly with 60-120Grit sandpaper to get Gouges in the plastic for the glue to grip onto, and cleaning the outside of the plastic with alcohol and tri-clor. whatever it takes to get rid of the oily smooth surface, and to a highly porus gripable surface.
