Bp044,
When the 2xAA battery case becomes available for the Ra Twisty, it will provide plenty of warning. The light will step down in brightness through a sequence of internal brightness levels and double-blink once a minute to remind you that you need to change the batteries. When the lowest internal level is reached, the light will blink continuously. No damage will be done to your batteries until you ignore this last warning. Note that this behavior is different from li-ion batteries, where no damage is permitted.
Henry.
Bp044,
Henry.
