Unicorn
The problem with holding a light out to the side is that it's harder to light up the target and shoot at the same time. It makes sense for some uses, perhaps searches, but not for actually shooting. Also inside normal rooms or buildings, it's pointless. The reflection will light up the entire room anyway. Even the refletion outdoors if the light is bright enough will do so if not in wide open spaces and the light isn't pointed at the ground.
While the light is flashed, you can get a mental image of what is there when you move. Usually though, it's not truly pitch black, and hopefully your opponent if there, will be more blinded by your light than you are.
Multimode lights are fine... if the function switch is separate from the on off switch. I like the way the Surefire R1 is set up. The rear switch is high, the side switch can be low, med, or high. You cn also set the rear switch to strobe with three presses if you wish. The Newer Fenix lights that have a separate mode switch is nice also. No more trying to hal press a switch or remembering to turn the head to get to turbo.
