Kestrel
Recently I did a Low Light / Night Fire (i.e. handgun & flashlight) class at OFA here in Oregon.
The one-day (actually afternoon through early night), 8-hour class involved both classroom instruction and extensive firing range practice, and concluded with a police-qualification course-of-fire (I'm not a LEO BTW).
I learned some interesting things in the class and wanted to post with a number of things to share.
I brought my two favorite small SureFires to the class, a 'Crosshairs' C2 and a 6Z.
(My larger C3, Z3, 9Z, & 7Z stayed at home, and my G2Z & G3Z aren't ready yet - starting to see a pattern? lol)
The 'grip ring' SF's were specifically designed for use with a handgun, and I have also found (through much usage) that this flashlight configuration works very well for me in general use as well. I do keep my SF C2 in my nightstand along with one or two other things. Both of these lights have been bored for 18650's and for the class I used my treasured Moddoo V2 XPG DD Triple drop-in in both lights (more on that later).
Clickable thumbnail below, regarding other things that are slightly off-topic for this thread. ;)
The class started with a classroom discussion on the more theoretical aspects of using a flashlight with a handgun, as well as the specific challenges of shooting in low light situations. First, some of the flashlight basics were covered, incandescent vs. LED, output, beam characterisics, switch types, single vs. multimodes, etc.
The instructors did state a preference for an output 'sweet spot' of ~100-200 lumens; they claimed that higher outputs could result in blinding reflections in close quarters. I have attended a few other OFA classes by now and am on reasonably good terms with the instructors, so I asked permission to quickly demonstrate something after they went over the aspects of hotspot vs. spill. (They already know I'm a flashlight junkie, lol.)
I went up to their graphic showing a typical beam pattern and fired up the XPG triple to overlay its beam on the diagram. I stated that this light was something like ~1500 lumens, but due to the absence of a central hotspot, I didn't feel like there were any points for concern, just a HUGE field of well-illuminated view (something the triple optics do far better than standard single optic or reflectored designs). I also used that opportunity to explain the difference between lumens output (something that everyone there was familiar with) and lux (which would be more related to the instructors' specific concern). My information was well-received and folks were comfortable enough to ask a few questions.
Some interesting things from the classroom session:
The instructors definitely preferred single mode lights with a rear momentary button, their reason being that if you drop your light it will immediately turn off and not continue to illuminate your position. No constant-on clicky switches! ;) Also, inadvertently changing modes during use was very undesirable as can well be expected.
One instructor demonstrated the usage of a lanyard; interestingly enough they had a 'take' on it that I hadn't run into before:
Not only did they recommend short lanyards (to facilitate the reestablishment of holding/utilizing the light after doing lights-off tasks such as reloading), but one demonstrated something I found very interesting: A small ring (it was actually a hand grenade pull ring) attached directly to the lanyard attachment point on the flashlight body. The instructor could have the ring around one finger, and when doing other tasks (such as reloading), the flashlight would dangle just under the hand, maximizing readiness for subsequent use.
On the range, they emphasized that immediately after you 'light up' and fire a couple of rounds (or even if you don't fire), after you turn off the light, TAKE TWO LARGE STEPS TO EITHER SIDE. Any opponent will most likely shoot where they last saw your light - needless to say you want to be anywhere but there.
Much was made about different handhold techniques, the "Overhand Grip" (i.e. the 'icepick' grip) and the "Base Switch Grip" (i.e. the 'cigar/syringe' grip) for the SureFire grip-ring-style lights. We trained with the 'Overhand-High', 'Overhand-Low', 'Harries', & 'Cigar/Rogers' as well as transitions between the different grip techniques. We did a lot of transitions during our live-fire training - fantastic practice. :)
I'm not going to go into detail here about how to use the individual grip techniques. Although I now have some small experience in using these, I'm definitely not an instructor and do not want to give any impression that I am qualified to teach these. During the range session I did form a definite personal preference for the 'Overhand High' and 'Harries' techiques - they were the easiest for me to quickly and reliably illuminate the threat prior to firing.
One thing I liked about the class was that we practiced a number of the popular techniques, not just the ones that anybody felt were the 'best'. The instructors emphasized that while one particular technique might often work the best for an individual, we did need some familiarity with the other techniques; furthermore some techniques would work better than others in specific situations such as shooting from behind doorways or low cover.
We did an hour or so of training while it was still light so we could practice the relevant techniques (supervised and in a safe fashion) that we would be using once it got dark.
One aspect I particularly liked was intensive training on doing handgun reloads in the dark - taking the flashlight out of use to make both hands available for reloading, while keeping the eyes up and towards the threat.
Some other memories of the class:
About halfway down the line, some poor soul was having an occasional difficulty with his multimode light - every once in a while I saw some strobing to my right. Handgun recoil, insufficient grip, or finger fumbling can easily interrupt the pressure on the 'on' switch, and a multimode light can easily change modes in this situation. I've been a firm believer in single mode lights (almost all of my P60 series SureFires are single mode) and my experience in this class reinforced that opinion.
Once it was dark, each of us illuminated our targets in sucession, while stating out loud what light it was so that others could see the illumination differences.
"Oveready XP-G triple" from station 2 :D It was gratifying to see my light not only completely light up my 10 yd target, but also the targets to the right and left as well.
I cannot emphasize enough how useful it was to have a broad beam with a resulting wide field of view - being able to see potential threats adjacent to your target instead of merely the tunnel vision you get with a traditional beam could quite literally save your life.
At one point during the 'night' phase, one instructor mentioned that one thing many of us needed to work on was to keep the light on the target during firing; they had noticed lights pointing up/down/whereever and not consistently directed for the best illumination of the potential threat. I was confident that the wide beam of my OR Triple was nearly always illuminating my target 100% and I could put most of my attention on evaluating the threat and making center-of-mass hits.
I can assure you that when you're trying to reload in the dark as fast as you can, kneeling down & hunched behind cover; you're cold and your hands are shaking and there is shooting up and down the firing line, it's a rather memorable experience. :)
Bringing this back around to flashlights, while I found that manipulating my SF C2 was pretty easy, I found the classic 6Z body style to be the best: Not only was it slightly lighter (making grip transitions easier & less likelihood of dropping the light), but the slightly narrower body section made the flashlight easier to keep full control of at all times. The older non-lockout tailcap button was simply perfect: soft and wide, easy to activate and keep on during live fire.
To say that runtime wasn't important would be an understatement, as we only used our lights in ~2-3 second bursts.
I probably did less than 3 minutes of runtime for the ~4-5 hours we were on the firing range.
It was an exceptional experience in every respect and I'm planning on taking it again next winter.
Any CPF'ers in Oregon, if you're interested in taking the class next November, please let me know as it would be fun to meet up.
BTW there are a couple of prerequisite classes for this, so sign up early if you don't want to be disappointed. :)
It was one thing to know some of the relevant illumination aspects in a theoretical manner beforehand, but being able to train with a variety of these techniques in a safe manner while supervised by highly-qualified OFA personnel was an outstanding opportunity.
Thanks for reading,
Kestrel
Thanks for reading,
Kestrel
