UpityCracker
- Joined
- Nov 4, 2007
- Messages
- 1
Hi everybody, new to the forums, but I've seen a lot of cool ideas already! I looked around for a while but couldn't find an answer. I volunteer at a local haunted house and we're thinking about updating our current theatrical lighting system.
Currently we're using small incandescent bulbs running off of a 28v system and would like to switch to LED for obvious reasons. I used the LED calculator at http://led.linear1.org/1led.wiz to figure out what resistor would be needed for our system and it came back with the correct sized, but also stated that 28v would produce excessive heat from the resistor when using a single LED. As it stands I believe every LED in the rooms will be supplied with a full 28v.
Are we trying to tackle this the wrong way? Are the resistors going to burn out and kill the LEDs prematurely? We can re-wire into series or parallel if necessary, but we were really hoping to be able to pull the old lights and swap them with LEDs.
Sorry about the length and thanks in advance for any help!
