LxD reflectors at Fenix-Store!
I would like a heavy OP for as much flood as possible. There just arent any decent floody leds available....
For $6 bucks, it might be worth it just to experiment with home-sputtering.
:whistle:
:whistle:
:faint:
Sputter, n. to sublime a material, i.e. vaporize aluminum, directly from solid form into a gas, and deposit it on a specific surface.
:eeksign:
We once "sublimed" a penny in an industrial oven...don't try this at home, kids! :eeew:
I meant to say "stipple", but you all got the idea :)
How does one go about stippling a reflector themself anyway? Do you need a sandblaster or something?
I think I'll try polishing my old reflector. Had my Dremel for 10+ years and never polished anything with it.
The "ghetto" way to do it would be to give the reflector a rough coat of metallic spray paint. Stippling involves adding metal to achieve texture. It results in the smoothest beam possible for a given reflector depth, at the expense of output and throw. In a small package like the LxD head, it makes sense as long as you're okay with the floody beam pattern.
This is good news because I tried to clean mine with alcohol with disasterous results. My order is already submitted. Thanks for the heads up!
What happened?
:popcorn:
mchlwise said:
What happened?
I was trying to get the reflector perfectly clean and I should've left well enough alone because I eventually got the hairbrain idea that alcohol would do the trick--it turns out that it strips the reflective material off quite easily. Now a six dollar mistake, but the worst part has been not being able to use my light.
For those of you wanting a floody beam, a stripped reflector does a pretty decent job.
:duck:
I thought it was a solid polished aluminum reflector. :shrug:
AyeMayanor said:
From FLR:[font=Arial, Helvetica, sans-serif]"Reflector Type .........................[/font]Polished metal"
Right. So how did alcohol strip the reflective material?
(I just ordered one to play with.)
