M6 + 3x2RCR123's + MN60 and MN61?
socom1970
The Heartland of America
Does anyone know if the M6 with six RCR123's will work safely with the MN60 and MN61 LA's? (I tried a search and found a whole bunch of threads, but didn't see anything directly about this. Sorry to any Mods if I'm wrong.) I wonder if this combo would be a safe and easy configuration for this excellent illumination tool.
I´ve tried the MN60 in a M6 with RCR123 and it works fine.
But I would never test it with the MN61.
MN60 works, MN61 so far looks like a 50/50, if your MN61 does work..expect the life of the lamp to be around 10 hours and you WILL see some black tungsten deposits.
Do a search for MN60 and MN61. There are quite a few recent threads, and posts discussing this very subject, also discussion about using 17670's.
Bill.
well...the one I know of its mainly built upon the constructs of failing MN61s
I oughta know, it was my thread
heres the runtime graph for the MN61 on 17670s
the graph is from c0t0d0s0's thread [that I apparently have not been able to locate]
Use the LumensFactory HO-M6R bulb if you want more trouble free operation on 3.7V RCR123 cells in an M6. The MN60/61 can often be used, but at the loss of bulb life, if bulb reliability is not high on your list of needs, then give it a whirl. Oh... and do keep in mind that the MN61 will be drawing ~1.4A or more from the RCR123s (~2.8A total, split between 2 banks), so it's pretty hard on those cells. The HO-M6R clocks in at loading the cells to about 1.05A per bank, which is a nice healthy maximum safe continuous discharge for an RCR123.
Power options:
mdocod, regarding the 6 x RCR123 and MN61, although they're still overdriving the bulb, would they also sag a bit more than 3 x 17670's? For the folks who like to push the limit would this be one step down in driving vs 17670's?
Thanks.
The MN61 is designed to work off 4s CR123A. 3s2p would not be over-driving it but under-driving it.
No, because the R123s are put into the MB20 battery holder in the same 3s2p configuration as the CR123A primaries, whereas the 3x 17670s are just plain 3s (series).
