To answer (1):
There would about an hour of regulated output, then about 2 hours of declining output, even before the protection circuit was tripped.
To answer (2):
They are described as 3.7v but are charged to 4.2v. The battery will be fully charged at 4.2v and empty at (I think, get an expert to confirm) 3.6v resting.
I use a 17670 in an ITP C10, and because I have it set quite low, I use it for what seems like ages, check the voltage, and I'm only down to something like 4.02v, and that's from starting at 4.1v because I don't fully charge them.
To answer (2):
I have a couple of questions regarding: gsnorm runtime test of an M60 with a protected AW 17670 cell that ran for about 1 hour (cell above 3.8 volts) of regulated output folllowed by 2 hours of slowly declining output.
(1) I was under the assumption that in a protected cell, the light would just shut off without notice when the protection circuit kicked in.
(2) I thought the 17670 protected cell was rated at 3.7 volts. If the cell in the test was charged above 3.8 volts in order to operate the M60 in its regulated state, would that damage the cell or can potentially damage the cell if usually charged above the rated voltage of 3.7?
Please note that I'm very new to rechargeables and flashlights in general so gsnorm please don't take my questions (lack of understanding) personally.
Thank you.
