I'm planning to do my first 2D Maglite mod. I'd like to eventually end up with one Seoul P7 with a multi-mode driver running off a pair of D size LI batteries but I'm planning to start much simpler and work my way up. Initially I'm looking at:
3x AA NiMH in series for 3.6V
P7
Direct Drive
P7 specific heatsink from H22A http://www.candlepowerforums.com/vb/showthread.php?t=203235&highlight=heatsink
I'd probably then migrate to 6x AA and a simple driver circuit as I learn what I'm doing. I don't plan on going over 1A drive current for quite a while.
My questions are:
* Given that I'm staying under 1A drive current for the near future would there be a better choice than a P7. They are pretty expensive ($20-$30) and I can get Cree XRE-Q5s, Cree P4s or Seoul "Z-power" http://www.dealextreme.com/details.dx/sku.1445
for around $5 each but I have no idea how efficient these emitters are or how well each would work with the Mag reflector. Any advice?
* Some of the emitters on dx come mounted to a circuit board for easier soldering and some don't. Any recommendations?
* If I end up using few mm worth of spacer material (aluminum washer?) to make whatever emitter I choose work with the P7 specific heatsink rather than dremmeling it flat will it screw up the focus too badly with the stock Mag reflector?
Thanks
Ray
P7
Direct Drive
My questions are:
Thanks
Ray
