Sold/Expired Mag D Incan Driver - Soft Start & Multi-Brightness
AW
Hong Kong
Not Available - Mag D Incan Driver - Soft Start & Multi-Brightness
Introducing the Mag D Incan Driver with soft starting feature, 3 brightness settings and flashing mode. This driver assembly is a complete drop-in to replace the stock Mag D switch. The all metal switch housing is built with a high temp. KIU bi-pin socket and the driver board enclosed within. Great for running hotwire super bulbs for up to 150W ( 200W intermittent use ). Input voltage can be as high as 30V ( max. pack open voltage ). Runtime can be extended according to your brightness setting. ( Note : This driver does not have output voltage regulation yet ).
Specifications:
- Soft Starting to prolong bulb life and ease the amperage draw on the batteries during power up;
- 3 brightness level ( PWM controlled ) - 30% - 60% - 100%;
- Last brightness setting memory ( default level - 30% );
- Flashing mode;
- Simple UI ( click - ON ( low ) - Med - High - click & hold anytime - OFF - click & hold 1.5 seconds - Flashing );
- Input voltage from 6V - 30V Max. open voltage ( Vin = Vout );
- Drive bi-pin hotwire bulbs up to 150W ( 200W intermittent use );
- Full alum./brass housing to withstand heat and better heat sinking;
- Power efficiency 99%;
- slightly recessed push button to prevent accidental power on;
- comes with 10mm, 15mm, 20mm brass posts and washers for different height bulbs.
Here is couple video clips of how the driver works :
Incan Smart Driver Video Clip 1
Incan Smart Driver Video clip 2
Special Notes :
1) Works with both cam and camless reflector
2) No Soft start for ' Flashing Mode '
3) The PCB mount push button has no momentary
4) Alum. reflector and glass lens required
5) Standby power drain of the circuit is approx. 80uA
6) Total internal resistance is < 30mOhm ( according to data sheets of components ).
7). Do not press the button switch too hard, a slight press will operate all the functions.
Installation is simple. Remove the stock switch with a hex key ( 2mm ) and slide it out from the rear
Insert the Driver Switch in and align the switch button to the center. Use the same hex key to tighten the hex screw. You may want to move back and forth a couple times on the last turn to make sure the screw pierce through the anodizing for a good contact
Price : $75.00 each ( ALL SOLD)
Shipping : $6.00 by Registered Mail
PayPal : [email protected]
The socket wires are soldered to the circuit board and you don't need to do anything about them. To replace posts with different length, you only need to unscrew the M3 screws on the socket and unscrew the posts. Replace with different length posts / spacers and that's it.
:drool: Wow.
Does the copper colored plate that the posts attach to unscrew so the socket wires can be soldered and unsoldered?
AW- I will take 1. PP shortly. Thanks sooooooo much for bringing these to market. I look forward to the regulated version.
Kirk
Edit: AW - :paypal: for Soft starter and a few extras. Thanks. Kirk
AW, thanks for an early Christmas present. I have many uses for these, as well as the regulated version, and wanted to thank you for all your testing and feedback with these!
2 Drivers $158 sent!
:paypal:
Paypal from DMC sent for:
2 Mag D Incan Driver - $150.00
Shipping - $ 7.50
Total - $157.50
Thanks AW!:goodjob:
I will take one, paypal coming!
:paypal: for $81.00.
Thanks for doing these. What is the timeline for the regulated version?
I have been waiting for a long time for this, thanks AW!
Shipping - $ 7.50
__________________________
Total - $157.50
:paypal:
Ok, I'll bite:
:paypal: for one Mag D Incan Driver: 81 USD
iapyx
:paypal: for a 2nd Mag D Incan Driver: 76,50 USD
thanks,
iapyx
