MAG-LITE switch...
FILIPPO
Italy
hi all,
I want to disassemble a mag-lite switch from the flashlight body but I don't know which type and the size of key I need:ohgeez:
can anyone help me?
ok, thanks!
I know that the question is stupid but I needed this information:)
Some little tips. Just remember to insert the allen wrench all the way through. You should feel a bit of resistance as you unscrew (i.e. turn anti-clockwise). Also, push in the switch button before you try to take out the switch otherwise it will catch. You will have to remove the switch from the bottom of the light because there is a retaining spring that stops the switch moving upwards.
