I did some searching, but I could only find the lamp life spec for the Big D Nicad version which is 30 hours, but it is proably safe to assume the SLA version has the same lamp life. The rerated lamp life then becomes 4 hours, so it is no longer a recommended setup when we see the short lifetime.
When the batteries are fully loaded and you turn on your light, then the voltage will be much higher than then quoted MPV I gave you. I think different bulbs will handle this differently even if rated the same life time, so there is no guarantee that a heavily overdriven bulb will not instantflash when you turn it on. It is therefore alway a good idea to rest the batteries for an hour after charging so the voltage drops a bit.
Using CTA will overdrive less than AccuPower (and is therefore less prone to instantflashing) and gives longer runtime than Powerex (which overdrives the same as CTA), so they should be a very good choice unless you later wants to use the WA1274 for longer runtime, then AccuPower should be the obvious choice. Who knew it could be so difficult to put together a flashlight /ubbthreads/images/graemlins/smile.gif
I see that Fivemega now sells some special made axial bulbs that can be used in this setup, I will try to get some specs I can use for rerating. Axial bulbs gives a rounder and nicer beam, but doesn't throw so far.
Sigbjoern
