Been reading through a number of threads and I am now ready for the real questions :)
I have a number of Maglites and I want to build one of them up as a dedicated thrower. Highest lumens+throw possible through normal purchaseable items.
As this is my starting point, I want to clarify some questions I had about what to do.
1) Glass compared to plastic lens - is there a noticeable difference if you go to glass? Is there a 'best' source for glass and are there preferable coatings?
2) Malkoff P7 appears to be the most popular dropin. Is this still the preferred way to go?
3) Can you shim up a C or D cell Maglight enough to use AA Eneloops? If so, what is the minimum amount of cells needed to drive a P7 dropin? Will it work at all?
4) Has anyone installed the 'tactical' tailcaps and bezels? What are the opinions on these? Durable and worth it? Just in the way?
5) Are 18650's just that much better a choice for driving a hot Maglite?
6) Is 1 starting host better than another? Is the LED Mag better to start with? Any size better than another?
7) Anything else I should know about doing a build?
I do not currently have a purpose for this light. Once I build one I will then figure out how it fits in. I would like for it to be my walking light, hunting light, car light, home light, etc. I know I want a thrower, it needs to be bright and durability is important.
Some of my questions can only be answered by 'depends' I suppose. Since I do not have a listed purpose then put in your own opinions for questions like 'best' :)
Thank you for the replies.
