I'm curious what the actual inside dimension is on the latest (3rd or 4th gen?) ML50L tube both length and diameter [beyond the threaded section]. Will a 26650 with normal dimensional tolerance fit without risk of jamming? Can the cap spring compress enough to fit two 21650 in the 2cell? (I am thinking of a parallel circuit setup not series.) I read in an old thread that even slightly oversized 26xxx cells are too tight in the ML25L. But as the ML50 is newer with a longer body and switch and the ML150LR uses a LiFePO4, there may be a chance that maybe mag wasn't too daft and gave the ML50L that extra 0.5mm ID. Of course they didn't give it a true off switch so there is loss in storage, and the H/M/L selection order is backward regarding saving both night vision and charge, so maybe I'm too optimistic.
I know the tubing thickness is drastically thinner than on classic mags, which is why they changed to fine pitch threads, so boring or honing for ID is likely out.
Also, do the 50L 2 and 3 cell versions use the same driver electronics? Wondering mainly about min voltage cutoff and max allowed voltage, and which would work better for either a single cell Li-ion or LiFePO4. I no longer have access to an equipped electronics test bench and being unemployed I can't justify trial and error costs. My intent is to buy a light now because I need one, probably run alkaleaks or ni-mh, then upgrade it in the future. Just juggling the various pros and cons of the four ML25/50 2c/3c models.
I'm likely over thinking things again and by the time I get to doing any upgrades my options will have changed again and I'll be able to afford to do my own testing. So in the mean time, latest 3c 25l or 2c 50L/x... hmmm I may be resolving my own questions already but I'm going to post the tech questions anyway out of curiosity.
