Looking online at the Maglite 2xAA Pro Plus and Black, I'm seeing a lot of different specifications. Is the Maglite Pro Plus a good double AA cell LED light? I specifically want something of reasonable beam and overall construction quality for $30~$50. I need enough fill to be useful for walking in a dark parking lot on a moonless night with enough hot spot to hopefully dazzle someone if I need to get away from them.
I'm not really interested in a ~$300 SureFire or ~$350 Modlite but, if there is a real difference for a light a bit above $50 I'm interested.
TIA,
Sid
The Mini Mag is a reasonable torch still. Although IMO they aren't so "mini" these days. They are quite long, which mean they aren't the most pocket friendly. The C-cell powered ML25 Maglite is significantly bigger and heavier. And would be quite a lump even in a coat pocket.
For me one of the biggest issues are the alkaleak batteries. The Mini Mag you can run alternatives, but the torch is engineered not to make use of the better batteries. The ML25 doesn't really have any better battery options.
Both torches are good off the shelf lights, that will work well with alkaleak batteries however.
In terms of beam, the Mags all have a focused and intense hot spot and somewhat dullish spill beam. Very traditional. This gives both of them good "throw", i.e. long distance beam for their relative size. But makes them less good close up or if you ever want to use them to look at a map or something very close to you.
I also find when walking, a bright hot spot tends to wobble about all over the show as you move. But they will let you see further down range. If you don't need to see as far away, a floody light with an even beam might be more pleasant, although you might not be able to see quite as far.
Generally the market has a bit of a lack of good 2xAA lights. But I'm sure the big players probably offer something if you want more modes and an advanced UI. The Mags are all pretty simple on/off type of lights.
That said, IMO there are way better lights out there for very similar money. If you are prepared to look at Li-ion power.
For example, this $20 flashlight is much more compact than a Mini Mag, better runtimes, more modes, choice of LED tint (for better colour rendition) and much higher lumen output, but will still offer a good throwy beam for a small light:
https://www.aliexpress.com/item/32887037637.html?spm=2114.12010612.8148356.6.7a5f121eAZOFZU Convoy S2+ with XP-L HI emitter.
If you decide you want floody, you can get the same light with a different LED for a completely different beam profile.
If you want something bigger, this $28 C8 would massively out perform the Maglites, even the ML25 and is still a lot more compact too.
https://www.aliexpress.com/item/33035996609.html?spm=2114.12010612.8148356.16.4ed66d6co4jzXy Convoy C8+ with XP-L HI emitter.
There really is great choice these days. With an 18650 light you'll need a charger and at least one battery (the C8 above comes with one). But these are cheap too.
If you want to spend a bit more money, there are some really nice lights out there.
For example, $50 will get you a Noctigon KR1. Much shorter than a Mini Mag but way more powerful. And way more throw than the ML25.
https://intl-outdoor.com/led-flashlights/noctigon-kr1-tail-e-switch-pocket-thrower.html
