Hi everyone,
I've had an inclination for a while to try and design a high-powered, battery operated LED light for filmmaking uses. High lumen output is key, and after an initial plan of setting up 4 Cree MC-Es, I discovered this LED:
http://www.newark.com/bridgelux/bxra-n3500-00000/high-brightness-led-arrays/dp/74R9818
3400 lumen
25.6 Vf typical
28.3 Vf Max
2100mA
I'm trying to figure out how to power this thing off of batteries. I'm looking at getting 7 AW 18650s (http://www.lighthound.com/AW-18650-...able-Lithium-Battery--New-Version_p_3125.html), and running them in series. (4.2V*7 = 29.4V) Will this work?
There don't seem to be any drivers that could handle this, so I'm thinking of doing direct drive with a resistor. Do any of you have any thoughts on what resistor to use? It seems that when the batteries settle in to their regular output of 3.7V that I will be losing a lot of current. Is this going to be a poor way to power the LED?
Thanks for sharing your knowledge!
(Also, this is my first post here.
3400 lumen
25.6 Vf typical
28.3 Vf Max
2100mA
