Gadgetman7
Does it flash regardless of how tight you turn it?
Yes it does.Does it flash regardless of how tight you turn it?
I don't think you need to worry much. I very much believed mine is just the one in a million lemon.These are supposed to be super reliable. Hopefully just a little glitch.
Update to my Mako...
I don't know what happened exactly. Was trying it out a few more times to see how bad the flicker is getting. As it got worst, I got frustrated and threw the Mako on my wooden desk. Guess what? Not only did the flicker disappeared, the low output came back!
I am not sure of what to do now. Is the Mako going to function flawlessly now? Or is it only temporal recovery? I have already written to Enrique but I doubt I will get a response from him anytime soon.
This seems to remind me of an elderly friend in his 70s... He took a fall and bumped his head and all of a sudden his vision is 100% cured! He now no longer use a reading glass. Hard to believe but I have witnessed it with my own eyes.
Yah right... Lol!Nice! Yes, flashlights, blindness, and it can work on amnesia too, provided the amnesia was caused by a bump to the head in the first place.
But it doesn't explain why the light flickers. Initially the low was much lower than the intended low and flickers between the low low and high. Then after a few times of turning off and on, I lost low output completely. On high, it just flickers on an output that is somewhere in between low and high, and high. Weird behavior there. I hope the issue has been rectified.Just a theory. Low mode is provided mechanically with a spring. Perhaps your spring was stuck "down" in the high position. The impact may have dislodged it. Just a theory.
