On high? For how long did it maintain full output?. I do know his website says 2 primaries only run 15 to 20 minutes or something like that, but I got well over an hour with used batteries and still had plenty of light.
Yeah, I just wanted to stick with Malkoff that's all.There are other options for e-series 18650 bodies without a reducer, but that would mean buying from a company other than Malkoff.
Yes, it was on high the whole time. I actually got aggravated, because I was running it and an E2XT at the same time trying to kill some partially used cells.On high? For how long did it maintain full output?
Neutral 95CRI MDC HA LMH V2 Li-ion Rechargeable Head – Malkoff Devices
Malkoff MDC LMH Neutral 95CRI (Low-Med-High) Head expressly designed 3.8-9 Volts. The output on high is approximately 550 OTF Lumens. It is a tailcap controlled multimode head. This head will fit Malkoff MDC Bodies and SureFire E Series lights. The head is constructed of 6061 T6 aluminum and...malkoffdevices.com
What's the exact head model used for the test?
I believe it is the Malkoff HA LMH Li-ion rechargeable. The link is in last reply![]()
Lol honestly I'm trying but I'm also very confusedLol now it's just getting funny.
The specs look about the same as the MDC 16650 500 lumen with XP-L. Do you think the only difference is the emitter?I believe it is the Malkoff HA LMH Li-ion rechargeable. The link is in last reply
Wow. I like that a lot I need to get this asap
Where do I find one?
What drop in are you using in this? I like that setup. I recently got the 1.5 and really like it. Thinking of getting the 1.0 to run an M61WL on.I got the md1 body from fivemega today and now can use the KP 1200 mah 18350's that are too long for the md2. This is a neat little setup, and the thyrm pocket clip works out perfect.
Just one mdx head away from having three complete malkoff's, but that can wait for now.
Right now I have my M61WL on the MD1.5. I was contemplating putting that on an MD1 and getting an M91BW to go on the MD1.5.Currently the m61t is installed. The M61WL is very well suited to this setup and will probably be the one I use the most in the md1. The WL runs 2+ hours on a 16340 so it'll be even better with an 18350, plus the md1 has the hi/low ring that you can't get with the VME head on an e series.
Yes they are. That is what I am using in my MD3 with a M91BW (Keeppower 2300 mah 18500's). They do well. I have been using a KP 2000mah 18500 in the MD 1.5.That'd be a nice setup. Maybe I should have bought the md 1.5 also. Those 2300 mah 18500's are impressive.
