Thanks mfrey. Another question, can the Mce2s also be used with the E2D tailcap ? If so then how are the SF internals removed ?No, the flat version is for use with the flat tailcap.
You need the standard LOTC version for use with the McTC. It has the rounded button to work with the standard rubber boot. The Shoppe has the DIY kit for $29 or the unit already assembled for $35.
Does anyone know a solution to put a 2 stage on a C body?
All of the 2 level tailcaps I have seen are E series.
Here is what you need for the C-series:
http://theledguy.chainreactionweb.com/product_info.php?cPath=48_56_70&products_id=642
Thank you. Do you know if this the same one, but preassembled? Is it worth the extra $5?
http://theledguy.chainreactionweb.com/product_info.php?products_id=641
A run is proposed here :Does anyone know of a current source for the C head to E body adapters now that Lighthound is sold out?
Received and installed my 60 ohm resistor two stage tailcap switch today. This is a worthwhile upgrade to my 6P, makes the Malkoff more usable as this low setting is very appropriate for indoor applications and will greatly increase runtime. The switch allows you to access the low and high setting with the tailcap button or to turn the tailcap to low and access high with the button or turn the tailcap to high. I like this flexibility.
The installation takes a few minutes and is straight forward as outlined in the directions referenced above.
I'm really glad I went with the 60 ohm version, 30 ohm would have been too bright for my needs and the newest Malkoff drop-in has a good hot spot even on the low setting.
Definitely a worthwhile upgrade!
Any idea how much energy is lost to the resistor?
