Vinh did you use the host with the SST40 or SBT90.2 emitter.
MT90only somes with SBT90 LEDs.
According to Martin and admitted by Astrolux, there is problem with the reflector geometry in the Astrolux FT03S SBT90.2. I wonder if the Mateminco version has the same problem with the reflector. I dotn think so. Beam is very nice as is. But I will check to see if there is a diff in the reflector.
I'm really interested in this light. I've been reading about the Astrolux version with Anduril and it has a problem where it steps down on Turbo very quickly, around 20 seconds before the light is anywhere near warm.
Vinh does this version with Narsil have a similar problem?
Did the name change from MT90vn? ...and if so, is the the MT35vn90 mini? How does it differ from the MT90vn?
Sorry for all the questions but the model naming has thrown me off a little.
Vinh, two quick questions.
1) Am I correct in understanding that this is a 26650 based light, YES
and if so, what cell do you recommend for best performance? I tested with Samsung 40T as its the best I got. I hear Golis 26650 is very good but I have none.
2) Is there any possibility to have the light delivered with a simpler, more reliable UI than either Anduril or Narsil? DriverVNX2 is available which I think is much simpler UI but it would add $70 in cost!
I'd like to give at least one of these lights as a gift to a relative who isn't a flashlight aficionado. Unfortunately, these user programmable UIs aren't suitable for use by non-experts, IMHO.
Simple Low high is all that is needed for the general
When do you measure the throw? On turbo there's a small step down in the first 5-10 seconds. I turn off Step down.
Measuring at max ramp would be better for comparing reflectors. I also saw a small difference with the old reflector. Also what mod has been done to give it better performance. Fatter 18 AWG wires, spring bypass, all connection cleaned for best contact, and beam tuning should it needs it.
Have you removed the AR window on the emmiter? I haev not delens this light. But I expect doing so will yield abotu 3% lumen and may be 4-5% intensity.
Bumping this thread to see if Vinh can answer some of these questions in the last couple of posts.
Looking forward to seeing the numbers once you remove the lens from the SBT90.2.
The bump in numbers is nice, but more interested in it reducing any green tint on lower levels that is reported with this LED.
Its interesting with the sbt90.2. I have the FT03s and the K30gt and even though they use the same led, the tint on the FT03s has a really green tint but the K30gt has very little. I'm thinking Acebeam was able to acquire an sbt90.2 bin with a more desirable tint.
I think it might be the same LED but different reflector gives different tint. They are green on the lower levels in the K65GT too.
