Stereodude
I hadn't seen these before. The MaxaBlaster is very, very impressive.
For those who want to know:
At first even I underestimated the dangers involved with a project like this:
One day, standing in the bathroom, I noticed a severe sunburned area on my forehead, at first not knowing where that came from...I suddenly remembered testing the Mercury arc lamp a few days earlier, protecting my eyes with a type 13 welding-filter. Conclusion: The rest of my face unprotected, in about 45 seconds (!!!) I 'ultraviolated' my forehead, causing those sunburn-marks!
That even when I knew the dangers involved: The downside of superhigh surface brightness: The 100watt mercury-arc lamp relatively has the highest UV-output of all short-arcs ! Down to the most dangerous, ozone creating UV-C !!
Oh.. and yes WINDSTRINGSS, very,very hot!! After switch-off the entire bulb glows yello-hot !! Thats why there always is the danger of lampburst! If I can find the time this week I'll try to photograph the bulb just after switch-off..
Regards,
Ra.
Hi Xe54,
I don't use the term 'luminance' because many members of these forums are not hat deep into the light-theoretics! Surface brightness is much easier to understand..
:hairpull:
I'm not seeing the maxablaster in the 08 Guinness book of world records?????
Hi guyzz,
I've been on vacation for a while, but now I'm back..
In the south of France there are many oppertunities to use Maxablaster to its full extend!
So here some beamshots I want to share with you:
A comparision with Maxabeam:
BTW: During this vacation I had to fully reorganise the electronics-division of Maxablaster: The electronics I used earlier died on me!!
The bad part: I had to settle for an inverter/ballast combination: The best ballast for the job needed somewhere between 90 and 260 volts input.
So now Maxablaster has an inverter mounted under its belly:
So the overall efficiency of the electronics went down to a 75% or so, leaving a total burntime of about 70 minutes on one charge.
The inverter produces a 220Volt modified sine. The ballast has a wide input range of 90-264volts AC and DC and is powerfactor corrected!!
This has one big advantage: There are two voltage-buffers (and one of them is very wide!), that means that the lamp always exactly gets what it needs.
Even the illustrious Maxabeam does not have an uniform performance over one battery-charge!
If Maxablaster produces 4005.76 lumens with a full charge, it will produce 4005.76 lumens with the batteries almost empty!!
Do you want to know where I stayed?? Look at this little village at a distance of 6.2 km:
And:
With the new electronics-setup the power has increased, I still need to measure the candlepower output, maybe later this week.
Earlier Maxablaster operated at about 85watts, now it is operating at 105 watts: It lights up my livingroom with about the same power as 50watt HID does! So the lumens output must be increased quite a lot !!
The new ballast also has a 115watt output... I've not dared to try that yet..
Hope you enjoy this. If more is to come, you will be the first to know !!
Regards,
Ra.
Very sadly, you won't find it for sale. It is a superlative, magnificent, stupendous, one-of-a-kind phenomenon, desdigned, created and hand-built by Ra himself (the OP). Only one exists. It has no equal.awesome! is a monster of light without end! where you can 'find for sale? :devil:
