CaptainRogersUK
Wwonder if Guy is pondering having the clip in Z shape, it is gonna be the only multi pocket torch to have at hand in a zombie apocalypse ![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Wwonder if Guy is pondering having the clip in Z shape, it is gonna be the only multi pocket torch to have at hand in a zombie apocalypse![]()
Hi WWWW,Thanks for the explanation, I was just really curious about the process. :thumbsup:
Hmmm,since obviously the zombies cant find us if they dont have eyes to see, since the Zeus be so bright we blind them![]()
Alex, Zues is a Zombie killer!!I'm with you completely Captain. I'm a zombie prep nerd.
Hi MUGATU,...or a lightning bolt?
Hi Guy. Check out the bolt spacing on a McGizmo clip. Similarly check out a jetbeam/Nitecore clip like you would see on a Jetbeam Rrt01. This is as close to "standard" as I've seen.
Hey Guy, you might also check out the Sunwayman V10r Ti's clip as well. I don't think the factory clip is great, but people make replacements for them. Speaking of that light, I would love to eventually see a nice throw head for Zeus with a infinite variable magnetic control ring as seen on the V10R and V11R. With the tail switch, I like the UI. But, with a bit more throw.
Th8tredude
Sent from my iPad using Tapatalk
We all are short on sleep, hence all the fancy lights.![]()
Daytime is for people without enough light. :candle:
Thanks gunga, KDM,
sorry, quote button is not working as expected..
Looks like I might need an extra 3mm of width to match those sizes,
where from research, the center of the screw holes at 7.5mm apart.
Don't think it will look too odd and more width can't hurt.
The thickness will be 1mm which is plenty strong for Ti.
Tgwnn
Simple, just design a clip that can accommodate the projected 3-4 mm of screw spacing variation....or, do what everyone ELSE did, which was just make one that works for YOUR OWN light(s).
I'd lean towards making your own work as perfectly as possible, and let the others figure out how to use YOUR clips if they feel the need, instead of the other way around (A lot of work to make clips for other people's lights?)
Of course, a new clip paradigm is long over due, and, you are probably the "guy" to come up with it.
