bluwolf
I have a Jet JVM-830 mill, basically the same as Daniel and Will's mill. It has oil cups for the lube points. The one for the spindle is under the belt cover. The plastic tubing runs down to the spindle housing but curves back up before going into the spindle. I can't seem to get the oil to flow back up the curve and into the spindle. The oil cup itself is higher than the top of the curve so I assume gravity should carry the lube up the curved tubing, but it doesn't. Am I missing something here?
Thanks for the help,
Mike
Mike
