Was practicing with the 6x26 HF mill I purchased. I had some aluminum angle, probably 6061 in a vise and a 5/8 4 flute tin coat cheap end mill in a collet.
Consulted my feed chart and I started at full speed for the machine, 2885 RPMs. Was very unhappy with those results so I cut it in half to 1425 RPMs (or near there forget exactly) and I did have better results, but still not what i wanted.
Rather than cutting, the end mill is melting and pushing the aluminum out of the way, even coating up the end mill some and leaving a heck of a trail behind me.
For cutting fluid I was just using a little WD-40.
So, I am about to order a couple aluminum specific 2 flute cobalt end mills from Enco, but before I do I would like some advice on what the problem, or problems may be.
Spindle speed? Feed rate? (was pretty much feeding as fast as I could turn those handles, then tried slower for a finish pass) End mill choice? Do I need to use oil/kerosene/cutting fluid?
Here is the mill I have, but this one is converted to CNC and he is just cutting the hell out of aluminum in this video:
http://www.youtube.com/watch?v=eUcxRgJgikA
