gadget_lover
I came across an interesting article today. It shows an attachment that allows LIGHT milling with a conventional drill press.
The concept is simplicity itself. It attacks the major problem with drill presses , and that's the fact that the bearings are not made to handle loads that come from the side. The spindles are not designed to hold on when side loaded and tend to come loose. This simple attachment simply absorbs the side loading.
The article is at http://warhammer.mcc.virginia.edu/ty/7x10/vault/ShopTools/PM-DP-Mill.pdf
As I understand it, the bearing is a plain bushing, and the "chuck" is an end mill holder with a straight shaft. It looks like the shaft goes through the bushing and into the drill chuck, allowing the drill press to raise and lower the tool as needed.
An X-Y table or machinist's cross-slide vice would be used to move the part you are milling left and right.
I can see where you could do this with the XY table for less than $125. I think you can get a cross-slide vice from Harbor freight for less than $40. I would expect the capacity to be rather light (3/8 inch end mill, perhaps?)
Just thought I'd throw this out there. I've not tried it, and I don't recommend it. I do like the inovative approach.
Daniel
Daniel
