Hi,
I have an old Mini-Mag Light that uses 2xAA batteries. What would I need and where would I get a "mod" to upgrade it? Also, is it worth it or am I just better off buying a new flashlight?
Hi,
Drill out the reflector so a 5mm led will fit. Trim a 5mm led to fit in the bulb holder (make sure polarity is correct or it wont light). Run of L91's and enjoy... Not terribly bright but I would think runtime should be good.
Edit: I recommend using a Nichia GS for the lower vf.
