mini maglight waterproofing
river rock
Fremont,california
not sure how deep this will work but i found if you fill and lube all the o-rings in a mini mag light you can use it under water i have only tried it in a cup for now but i will be going bigger i am useing 100% pure petroleum it works very well and once i find out more of how deep it can go i will update:) Any other things that work please post
For what it's worth . . . .
I once read of a fellow who subjected a standard Mini-Mag flashlight
to a depth of 200 feet, and it worked fine. Suffered no ill-effects.
Note Well -- he did NOT activate the switch (twisty) while underwater !
:candle:
_
Ahh, yes . . . .
But you are not at a Depth of 200 Feet !
That makes quite a bit o' difference.
:devil:
_
Ahh, yes . . . .
:devil:
_
I dunno. Given a well-sealed inductor and stuff, the mag light could be flooded without (immediate) ill effects. There's not much high-voltage going on, and water's not THAT conductive.
The real, "acid test" would be . . . .
Has any water gotten inside ?
Not simply: "does the light still Work" ?
BTW, i read that account many years ago, so it was the old, classic "hot-wire" mini-mag.
Certainly sounds like something FUN to test, eh ? ? ?
_
