[ QUOTE ]
LEDagent said:
SJackal,
How does the Nuwai's brightness compare to your Surefire L2? If you do a ceiling test it should give you an immediate answer to which one is brighter.
I am hesitant to accept many manufacturer's claims to their flashlight's lumen capability. From what i've heard from Mark's review, he said that he would rate the Nuwai somewhere between 40-60 lumens. Still, pretty damn bright. I usually test my flashlight's brightness against known lumen rated flashlights like Surefire. I consider the Surefire L4 really 65 lumens, and base every other flashlight on my L4. I think the L2 is the same.
Anyway, this is a great review...it only makes me want to buy this one even more. Thanks for the review.
[/ QUOTE ]
How careless of me not to mention the ceiling bounce test!! The Nuwai's lumens are rather exaggerated, the 3 watter no where close to an Surefire L2, which is after all a 5 watter, and Surefire is known to be conservative in their ratings.
Alright I done the ceiling test in an enclosed room which is approximately about 12X10X9 feet space. The walls are white and there's furnitures (my bedroom).
Comparision lights are as follows:
Nuwai Quantum III 3 watt
Longbow Micra 1 watt
Surefire L2
Surefire 6P with P60 lamp
NEC Fluoroscent tube, Daylight 15 watts(from my aquarium)
The ceiling bounce test shows that the Fluroscent tube lights up the room adequately, but a somewhat gloom to it, a 30 watt tube would light up the room brightly for office use.
The L2 appears (at least to me), to be about half brightness of the 15 watt flouroscent tube, and it gave the white walls a very slight pinkish tint. The 6P is slightly less, and the room is yellowish.
The 1 watt Micra and the 3 watt Nuwai comes up to about the same brightness with each other. There is no noticable difference to the naked eye. Both the Micra and Nuwai is about 50% to 60% of the L2/6P's brightness as it appears to me. They are however, brighter than the L2's low beam.
Although from the above comparision it's about a quarter of the 15 watt fluroscent tube's brightness, but it is more than enough bright to light up the whole room to see adequately, and that is impressive. Afterall, we are comparing a pocket sized light against a fluoroscent tube. It is certainty able to surprise the average Joe by lighting up a dark room with that pocket light.
