Hi everyone. I'm new. I'm informed, and now I'm dangerous
Ok, so I decided to make a super-flashlight using a Ryobi P700 flashlight which uses a standard Ryobi 18V NiCd pack. I liked the Ryobi because it's hearty (high current wires and on/off switch). And the plastic is easy to cut and modify.
So, I removed the incandescent spring fixture and installed one of those two pin ceramic plugs. I'm using an Osram 100W 12V HLX bulb.
Everything works great...except I blow bulbs like no tomorrow. They last about 500ms before the filament blows. I've let the battery pack sit for 24 hours after charging but it's just too much current.
I did drain one battery to about 50% power and it worked for about 120 seconds before the battery died. The bulb survived though.
My question to all the experts here is, what do i have to do to get a fully charged pack to NOT blow bulbs? Put a resistor in series? Parallel? I'm not very familiar with electronics.
Any suggestions would be great. Here is the Ryobi base I'm using:
http://cgi.ebay.com/RYOBI-P700-CORD...ryZ20760QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
