jasonck08
So I've got this nice looking 50W 6v halogen spot light with some sort of a 6V battery inside. I opened it up once to replace the bulb. I think the battery is dead and was thinking about throwing 12xAA's in there and slightly over driving a 12V 100W bulb.
I have a few questions... The batteries I have are all Ni-Mh's ranging from 2100 mAh to 2500 mAh. I have 4x Sanyo HR-3U 2500mAh, 4x HR-3U Sanyo 2100 mAh and 4x Panasonic HHR-3EPA 2100mAh cells. Is there a problem to mix different types of cells? Obviously the lower mAh cells will wear down faster.
Do I direct drive the 100W bulb from the 12AA's? Is that bad for them? Will they provide enough current? If I'm not mistaken would the current draw be about 8000ish mAh from each cell? If so then I believe that is too much. Is it true that most AA's can only take about 5000mah? If that is the case, then maybe I'd be better off overdriving a 50W 12V bulb...
Thoughts please!!!
Thoughts please!!!
