Sold/Expired Multi-Sink
Re: 8x 7135 driver
Charles thanks for the help
:paypal:
3 - XP-G R5
1 - AX2002
3 - 8x 7135 Mutli-Mode
1 - 8x 7135 Multi-Mode Add 1x AMC7135 1400mA, Total 4.2A
1 - 8x 7135 Multi-Mode Add 2x AMC7135 1400mA, Total 5.6A
Shipping
Registered Mail
Rv7a
I might soon buy the rest of your 7135 drivers again. How fast would you have more in stock? Also, if you do make another batch, please (if you can) make the following changes:
Make the + terminal to the LED farther away from the outer - ring. I accidentally soldered a path from the + and - and it heated up and shorted.
Make the driver accept higher voltages. 12~15v would be nice.
The strobe in the Hi-Lo-Strobe is really slow, it should be sped up.
Also, when will you have a second run with your Multi-sinks? I'm dying to have one :D.
On a positive note, your drivers are really good for the price. And shipping from you is really fast. :thumbsup:
Thanks for your support.
Plenty in stock. Should cover most of your need.
1. The battery positve and LED positive are common.
So just use the battery + side would be easier.
2. It can accept 12-15V if you put more (3x) LED in serial setting.
7135 accept 3-6V only. I did use this setting in car dome light 12-14V with it.
If 1.4A output is enough, try my AX2002, 15V max. input.
3. The UI can't be changed, sorry. Mode 1 should be faster.
4. PM sent.
Please see the link below for more details.
http://www.candlepowerforums.com/vb/...d.php?t=201392
:paypal:Unique Transaction ID #1GS844147Y936123P
1 - AX2002 3 mode buck driver.
Hi Download, I may have missed this in the thread, but have you any news on the second run of the Multi-Sink ?
Still need a little bit time to prepare, please wait patiently.
I would like to order:
1 - AX2002 Multi-level Buck driver @ $10 + $4 shipping = $14.00
Will send PayPal payment soon.
Thanks - Matt
Hi Charles,
i would like to order:
1x E. XP-G R5 WC 14mm board = $9/pc
1x F. Connecting socket, 80C 300V 22AWG, 1 set = $1
1x G. 8x 7135 driver, 17mm - Mutli-Mode, $9/pc
1x J. AX2002 Multi-level Buck driver = $10
1x shipping to Worldwide = $4
total = $33
:paypal:
Thanks M@wurst, items were sent.
aurum, color bin is WC, cool white.
Hi, is the AX2002 Multi-level Buck driver 1A or 1.4A max now? thanks.
