Barbarin
Some pictures testing our newests lights. We have introduced some improvements on our dive lights, and I wanted to show them.
As you can see the differences are greater when you are perpendicular to the beam, but when it is near parallel to the picture axis, they are not so noticeable.
The "target" is a 7 l. cylinder. The lights are 5 meters away from the target on first series, and 1,2 m away from camera. 2 meters away from target on second series.
You can see too some green strobes on the floor.
The "contenders" from up left to down right:
1. Barbolight U-04 Mk. VI. (next generation of U-04's, improved driver, improved reflector.)
2. Barbolight U-15 Mk IV. (2008 model, 4x KLC8, 20 mm. reflectors)
3. Barbolight U-15 Mk. VI.(2nd Q 2009. D bin P7 LED, Improved reflector)
4. "xxxx brand" 18 Watt HID lamp, with "EKPP type reflector".
And one picture with all of them lighting at the same time (and some other which were tested)
From left to right:
U-04 2008, U-04 2009, U-04 "proto", U-15 2008, U-15 2009, 18 watt HID.
And FYI a comparison U-04 2008 vs U-04 2009.
From left to right:
