I have three Milwaukee 18V 2.4Ah batteries that I've rotated, usually keeping two fully charged, for the last 3 1/2 years. Two came with a drill, one with a cordless Sawzall.
I had been using my drill, swapped batteries, and put the one I'd been using on charge. About a month went by, and I went to use the drill again-dead battery. Took the one off the charger-dead also. Luckily the third battery was in a toolbag in my basement, and worked fine.
So I've got two dead batteries, and they've been sitting here for a couple of months 'til I remembered them. The day I discovered they weren't working, both were reading a little over 1V on my MM. Now one is reading 1.0, and the other 0.0. The charger light does not come on when I try to charge them(though it originally did on the dead one that I'd put on the charger).
My tools have only seen heavy use that really depleted the batteries a couple of times(I use a corded Super Sawzall for real work), and that is very rare. 90% of their use goes to my drill as a glorified screwdriver.
They're not very old, not heavily used. I expected many more years of service from these >$100 retail batteries.
So...what do you think killed my batteries?
I don't suppose there's any way to revive a dead NiCad battery
Aha...I just found out there's an upgrade kit with a charger and 2 18V Li-ion batts for a couple hundred bucks. I'm tempted to wait until the last battery goes dead and get that instead of replacing the NiCads.
